Budb66ExplorerMay 08, 2017Engine Coolant ChangeHow important is it to flush the cooling system with distilled water? To flush my system 3 times would require 30 gallons plus the 5 gallons to achieve a 50% solution.
MitchF150NomadMay 08, 2017Really depends on how hard your tap water is... If it's really 'hard', then you'll get calcium build up in the rad fins pretty fast..Just gotta do what you gotta do... Flush with tap or distilled. Your choice.Good luck!Mitch
Related ContentEngine CoolantEngine Coolant Color ChangeNear engine overheating gaugePotential engine overheatingChanging Coolant System Flow Path Plus Electric Fan
