smlranger
May 30, 2014Explorer
Engine Coolant Color Change
I had my original coolant drained, system flushed and refilled with Fleetguard ES Compleat OAT coolant. This was done at my local Cummins
Coach Care center. I've had work done there and have no issue with the quality of their work and no reason to mistrust them. This was done one month ago.
ES Compleat OAT is a deep pink/light red color. I have driven the coach about 500 miles since the change and the coolant in the sight glass on my expansion tank is now light amber in color. I thought this was odd and called the Coach Care center and they are at a loss to explain this. I took a sample of the coolant to them today and they tested it with a refractometer and the test strips and it tested fine. Freeze point was -32F and the test strip showed all other measures fine (this was done in my presence). At this point they think the coolant is fine but say they have never seen this happen.
I have placed a call to Cummins Filtration and hope to get a call back from one of their tech folks. I have no reason to question that the coolant tests fine but am more than curious why this dramatic color change in this short time period.
I am curious if anyone here has heard of this.
