jatin5's avatar
jatin5
engine coolant reservior
I'm having a hard time finding a radiator cap for my engine coolant reservoir, which needs a 15psi cap. any help would be appreciated. I don't know if I can put a 16 psi cap on the there.
thanks Barry
06 Camelot-400-ISL engine
  • Before you do that, go over to the Monaco site and do a search for coolant reservoir and pressure caps. Most of those tanks are of a "nylon/plastic" type of material and are subject to rupture if pressures get to high. On my 05 ISL400 in a dynasty, the cap was 8 lbs as I remember. (now sold). In any case, at least give Monaco a call with your coach id number and ask what was original pressure cap supposed to be.
    http://www.irv2.com/forums/f115/
  • check with knects if they don't carry it they can order one one for you.
    at least they found one for me a couple of years ago
    they are available on ebay also
  • I would think a 16 lb. cap SHOULD be OK but have you tried a dealer for that engine/chassis manufacturer?
