Anyone know what kind of oil is put into a 2014 Coachmen Mirada. I do not know if it is regular oil or synthetic. Does it matter if I switch it to regular oil. Is there a place in the coach that say...
I would assume a 2014 is still under warranty? Then I would recommend doing what the owner's manual says and using the products the owner's manual says to use. After any warranty runs out, then experiment with different oils.
