WE had two 8.1l vortecs from 2001 to 2012. The second one pulled us along for 110,000 miles with only a replacement of the exhaust donuts at 90k. It did have some quirks. the dash would reboot from time to time - disconcerting to have the Tach and speedometer drop to -0- and all the instruments flat line and then go through their "normal" start up routine - all at 60 mph! The engine derated (reduced power setting) a couple of times when the oil foamed at high temperature. Also once while climbing through Vail CO on I70 it coughed and missed a couple of times just shy of the peak. that was heart stopping, we were pulling at about 5,000 RPM at 28 mph. Your issue sounds like it derated because of the abnormal start, it maybe oil pressure had not come up fast enough because of the long storage time.
