deltamaster
Dec 24, 2013Explorer
Oh yeah, If I recall you mentioned something about finding oil.
Was that underneath the rig? On the frame/chassis? Under or all over the underside of the engine?
When did you find the oil? Was it at the place where you stopped? Did you say something about someone else seeing it? Have you had a mechanic look at it?
From what I read on the internet the light you described is a warning that the system is shutting down the engine to protect it. There were references to low fluid levels such as oil and coolant.
Have you checked those fluid levels?
