rgatijnet1 wrote:
and it could also be water that was ingested in to the air intake and has soaked the air cleaner paper element. Did you drive in the rain?
Painter3066 wrote:
Left for Florida last night and about a hour into the trip engine started to backfire and hesitated while going up hills. Ran fine on flat road going back home but engine missed a lot.
The symptoms you described were exactly like the ones my RV experience on a trip in heavy rain and it turned out as rgatijnet1 stated. Water had went in air tuba, which faced forward, causing the air filter to collapse, starving engine of air. Replaced air filter and solution to prevent in future was to cut air tuba, spin backwards, and clamp. There are several post on the site about this problem, just something to check and cross off your diagnostic list. Of course if you haven't driven in rain recently, disregard. Good luck
