KristinU
May 05, 2014Explorer
Entry Door Strut - anyone add one?
Has anyone added a gas strut on their entry door?
Our door needs to be stopped at 90 degrees because of the awning right next to it…which I already proved as a necessity by having the wind whip it and bash a nice hole in the fiberglass on the door when the awning wasn’t out – it hit the little foot bracket part on the bottom of the awning arm. Additionally, we have a “stay open” bar thing that is simply two eye type hooks screwed to the exterior wall and the door into which this little bar gets hooked into to keep the door open. Problem is that both DH and I have forgotten that it is not a gas strut and yanked on it too hard, and now a friend has done the same thing but had more brute strength and took care of one of the eye hooks once and for all. So it is time to find an alternative.
Gas struts make me a little nervous because you have to be sure they’re the right size. We are pretty confident with lots of DIY stuff at home and on the RV, but the struts are making me consider making an appointment at an RV shop. Anyone have any experience or words of wisdom? Or any other solution that we should consider?
Since ours is a previous rental, I'm not sure what would have some stock on a Winnebago Access 31C in 2008 - anyone know?
Many thanks!
Many thanks!
