Do you bring in the entry step when storing for any amount of time? The reason I am asking is because when I cut power with battery disconnect switch and exit the vehicle, the step does not retract w...
My battery disconnect and coach shut off switch is by the door so I stand on the ground outside the door and take a small magnet and hold it next to the switch on the door jamb (this "tricks" the steps into thinking the door is closed) and the steps retract. As soon as the steps are retracted I pull the disconnect and turn off the coach power switch. The steps will stay in then.
The thing to remember is that when you turn the power on the step will extend so watch your shins!
