Do you bring in the entry step when storing for any amount of time? The reason I am asking is because when I cut power with battery disconnect switch and exit the vehicle, the step does not retract w...
If I am parking where the steps might get hit, rest area, truck stop, storage yard I keep them pulled in, otherwise I leave them out. In my prior coach I just jumped down after powering the coach down with the steps in. The current coach I can leave enough juice on to just leave the steps in the on mode so they close when the door is closed. Solar panels make up the parasitic loads in the coach easily.
