Bartviii's avatar
Bartviii
EPDM rubber roof on 1997 monaco windsor
Ihave a 1997 monaco windsor, 34 feet long. I have maintained it completely since I have owned it (15 years). It has always been stored under cover. Today I noticed that my EPDM rubber is starting to flake (the white top part) and I can see grey underneath it. It doesent leak. This is happening where the air conditioners drain on the roof. Do I need to invest in a new roor??? Thanks for any help inadvance.
  • Make sure those are actual flakes... I thought mine was flaking and then discovered it was really fine dirt that had caked and was very hard to get off. I had to scrub the area with a soft brush and water to get it back to looking normal.
    2 years ago I had an RV detailer use a two step coating for EPDM rubber. The roof came out looking like new and still looks good today. No bubbles no peeling.
  • Check out Bus Kote. It's a good product. I've used it
    many times. It's diy.
    Bob
  • I tried liquid rubber products and the roof looked OK for one year. Then started to bubble and look like alligator skin. Would not recommend doing that again.
  • EPDM roofing can be recoated, they sell a product for this, don't have the link but I think its the cheapest way to go without replacing the roof material..
  • Click here for my story about a new roof.
    My MH is 1996 and I finally decided to get a new roof before leaving Florida this past Spring. If your 1997 MH has been in the Florida sun all these years then you should consider getting a new roof soon.
    It might be worth your money and time to take a vacation in St Augustine while getting a new roof. If you decide to go send me a PM before and I can give you advice on how to save a few bucks.
