Jim
Jul 19, 2015Explorer
You are low on oil, or as Accumack mentions you have a loose connection. You have run enough tests proving that the keypad and controller are both good, so look for something else.
BTW, if the lights 'flash' on the unit, the fuse is definitely good, no need to even check it.
When my Power Gear shows the symptom of just the light flashing once when I turn on the key, I switch off the key, pull the rig out of gear and jamb it into Park. Then try the key again. Or if that doesn't work, then go out and check the oil. One time I found that symptom was caused by a broken wire on the main solenoid.
Good luck.
Good luck.
38,763 PostsLatest Activity: Dec 05, 2025
