I use a 3/4" wood chisel to remove the mounted old sealant. Care is required to not gouge into a rubber roof, metal, fiberglass and metal are easy. After removing old sealant brush out crack and wipe down with cleaner. When applying tape use care to line it up a section at a time. Use a wallpaper seam controller to compress the tape.
