stillthinking99's avatar
Aug 05, 2014
Excessive engine heat transfering to bedroom
I have a new to me, 40' 2007 monaco camelot, cummins 400 ISL, that transfers an unbearable amount of heat into the bedroom while driving. If its 100 degree day its all the worse. The heat migrates into the walls, the closets, and the bed. When I arrive at my destination the 50 amp shore cord is so hot I can hardly touch it. I have tried to run the rear air on generator but it eventually trips the breaker - I assume because the walls, which included the main breaker service panel, get so hot that the resistance in the wires is more than the breaker can safely handle.
I found this burned up Camelot at http://en.visonerv.com/cgi-bin/md/M11017/s2.pl and called them asking why it burned up. They didn't know and had no way to help me find out. The person there suggested I have a turbo leak.
The previous owners complained about the heat since they took it home new. RV dealers (or someone) installed more insulation and an exhaust port or hot air port in the engine bay door. Neither fix seemed to help much.
Any ideas? Turbo or exhaust manifold leak?
Thanks
