mike24
Apr 17, 2015Explorer
Exercising Generator
How often do you exercise the onboard generator, and do you put it under load and for how long. Do you use the a/c for load. Thank you
tpi wrote:
I run mine at least once a month and often a bit more. I use the AC for load in warmer weather and an 1500 W electric heater to load it in cooler weather. You need to run it until the crankcase temperature stabilizes to drive out condensation, and the exhaust system dries out. I run it at least a half hour, sometimes more in cooler weather. Good time to vacuum and do other tasks requiring 120 volts.
