slickest1
Apr 05, 2016Explorer
You can run with it on or off, it is personal preference. It will not hurt anything or cause carbon buildup. When the switch is on and you take your foot off the throttle the e brake will engage. As you slow down the Allison will shift down once it is in the right rpm parameters. It will keep shifting down as you slow down. If you look at your shift pad it will probably show 2nd gear. It won't go directly to 2nd but will work it;s way down as you slow down.
On a long downhill that is fairly steep it is best to slow at the top of the hill and start down with the exhaust brake holding you back without having to use your brakes. This will save you from overheating your brakes and once they get really hot they will not hold you back. If you start down slow and it is too slow you can always go up a gear till you are comfortable. If you start down too fast you can overheat your brakes very quickly.
38,769 PostsLatest Activity: Mar 31, 2026
