DSDP_Don
Apr 05, 2016Explorer
It looks like you own a 2000 Winnebago Ultimate Advantage that comes with 300 HP Cat in a Freightliner chassis, with a Jacobs exhaust brake.
Your exhaust brake, when activated, basically blocks off the exhaust and causes the engine to build back pressure. At the same time, your Allison transmission will try to start downshifting, usually showing 2nd gear in your shift window. As the coach slows, the Allison will downshift until it reaches second gear. At some point, usually about 15 mph, your exhaust brake will disengage. (Some coaches are programmed to only downshift to 4th gear).
You can drive with the exhaust brake switch on and it WILL NOT engage as long as you are pushing, even lightly, on the throttle. Once you let off the throttle completely, the exhaust brake will engage.
Your exhaust brake performs better as your speed slows and you begin to downshift. You need to experiment with yours and see how well it works at different speeds. If you were to crest a hill at 60 mph and then start down the other side at that speed, your exhaust brake won't give you much help until you get your speed down to about 45 mph.
Some coaches, the cruise control won't engage when the exhaust brake switch is on. There are a lot of parameters that can be changed on newer coaches, so the exhaust brake will allow you coast when your foot is off the brake and some other changes. I don't think there are any adjustments on the older models.
Keep in mind in slippery conditions, you may want to limit your exhaust brake use. Applying it could cause you to spin out or lose traction. If you can, leave the switch on while driving, unless it cancels your cruise control. It's one less thing to worry about in a panic stop.
When in traffic or around town, you should leave the exhaust brake off and use your service brakes. Excessive use of the exhaust brake (lack of using the service brakes) can cause your brakes to burnish (glaze) and develop a squeal.
38,769 PostsLatest Activity: Mar 31, 2026
