mattdenryter's avatar
mattdenryter
Exhaust sputter
Hello all,
I am posting this for a friend of mine. He owns a 2003 fleetwood pace arrow 37A. Chevy workhorse 8.1 L. He recently noticed a sputtering noise from the exhaust tailpipe at idle. No noises from engine compartment. Engine starts right up every time with no issue. Any ideas what could be the cause of the exhaust sputter?
Thanks all.
  • Depends on the type of sputter. First thing I would do is make sure all the spark plug wires are pushed on all the way. The 8.1 was notorious for spark plug wires coming off. The problem was that because of the short length of wire, it was very easy to not install the wire all the way. As a result, they would come unplugged. Its not a persistent problem, once they are plugged in correctly, they do not fall off. Its just a matter of difficulty getting them plugged in all the way. If someone is just the least bit lazy, they will miss one or two. You need to make sure you feel the snap down into place, rather than just pushed on.
  • How many miles?
    Has he ever had the exhaust manifolds worked on?
    Do the Actia dash gauges work ok?....All characters on the digital display readable?
    How old are the tires?
  • Thanks, will tell him to run it for a bit and see if that helps. I want to make sure nothing is major with it cause I am considering buying it from him.
  • Could be condensation in exhaust.
    Start engine and run for at least an one half hour to rid exhaust of moisture.
    Does sputter go away? If so it was moisture.
    If sputter persists then do tune up. Plugs for sure but Rotor cap, rotor and wires if it has been over 2 years for these parts.
    Have timing checked.
    My guess is the warm engine will cure the problem
