dalenoel wrote:
The 4 way does go where you are saying and yes I have read and seen the videos and no I am not trying in the wrong area. Here is a photo so you can see that I really do understand. BTW I have built and designed 17 manufacturing plants.
https://photos.app.goo.gl/PYrmoK4oxRUioDBA6
Regulator is to the right
Still wondering if there is an alternative
You have a electrical solenoid for the shut off. You are just going to have to convert to a different fitting unless they have something else. If you have a propane place near they might be able to help faster than you can find the right fitting. I thought that that type valve had been removed years ago to a manual shutoff. Probable wrong in my thinking. But the propane shop should know for sure. Maybe Doug will ring in.
