navegator
Apr 27, 2022Explorer
Check the space on the left side between the transmission cross member and the differential from the rail frame to the drive shaft, if there is nothing there you can install a Ford 75 gallon tank with a switch over pump and switch over valve, these are standard in some E350 and E450 units the 55 gallon rear tank is standard.
You probably can find a good tank with the hanging brackets, straps, transfer valve, pump and maybe the electric harness at a junk yard.
navegator
navegator
