dons2346
Jul 26, 2015Explorer
Racorman wrote:Born To Travel wrote:
I would find the starter relay and measure from there to where the battery will be re-located and go to the auto parts store and get a new cable that length... The longer the cable the more resistance and the less amps there will be for starting.. cables are a common item at the parts store..
I just figure that if this does not work....... I'll buy a bigger starter battery. Money is no object with this rig. We got it for 1/2 price.
Buying a larger battery doesn't solve the problem. You still have to get the amps to the starter. By extending the cable run, you are adding more resistance and could reduce the amperage being supplied.
You need to use a cable resistance chart to determine the correct size cables. A good one can be found on the West Marine website or on the Blue Sea site. Remember, you have to figure the total length of the cables meaning from the battery, to the starter and return to the battery
38,782 PostsLatest Activity: Sep 10, 2026
