down home wrote:
DrewE wrote:
down home wrote:
Also if by chance there is only a 15 amp breaker in the panel change it to a 20 amp.
DO NOT do this. The only reason there would be a 15A breaker in the panel is that the house wiring connected to it is 14 gauge wiring, and "upgrading" to a 20A breaker would be contrary to the electric code and arguably a fire hazard.
Who has a code allowing 14 gauge wire? You couldn't run but one plug in on it.
Our last home built in 1970 had 10 gauge solid wiring.
My house has one 15A CB with 8 plugs on it and a lot of 14ga wire all to code, built in 2006.
When the saw wouldn't cut a 2x4 I thought there was a problem. Nope no problem. Fortunately the garage has a dedicated 20A plug.
