momanda1 wrote:
Ok if you think it is something I should not do myself can you give me an idea of what you think it will cost to have it fixed. I am slightly confused. What I think I heard you say was the cord needed plugged for the generator to work...however, nothing is plugged in at all and the generator does run from the button on the drivers control panel.
Yes the generator can run and not have any load on it. I do not know if it is powering up anything, that is why I stated that maybe an electrician should look at it especially with the wires just hanging out of the 4x4 box.
As to the cost I would have no idea what it would cost. I myself do not charge my friends anything to fix their electrical problems. I wouldn't think that it would cost that much though to check it out and install a power cord. Now if something has been modified that is another story.
As a side note never use a cord with a double male plug. You can get killed with one. JMO
