jwmII
Dec 22, 2015Explorer
DSDP Don wrote:
It's hard to tell from the photo, but if there is room, I would add a piece of thin angle iron over the length of the sag or replace the steel that is there with a piece of angle iron.
Good Idea. From the pictures it looks like something like suggested above would work. Use clamps or a small jack or two, to push the materials back together and drill and thru bolt in place using flat washers on top to spread the pressure from the nuts out. No way this is a thousands of dollars fix.
