jeffwhite
May 07, 2020Explorer
Eze Gutter, how to re-adhere? Double stick foam adhesive?
I've got the Eze gutter "stick on" drip edges around my windows. For the most part, they work well, however, on a couple of the windows, the edges that are curved to a vertical position (down the side of the window), it's starting to come off. Replacing it is very expensive (about $2 a foot). I'm wondering if anyone could recommend a really good double stick tape (with a little cushion, like foam, to made a good fit) that I could use to replace it. There is a decent amount of pressure when the drip edge curves 90 degrees around the window, so it would have to be of high quality. Any thoughts?
