walterinbaja's avatar
walterinbaja
F53 and code P1299
Ford V10 chassis engine temperature gauge shoots off the chart, but not actually over heating. OBD2 shows temp at normal but throwing code P1299 cylinder head temperature overheating. Pull over reset code and all is good for 15 minutes to a hour and then temp gauge shoots up and engine goes into “limp home mode”. Mechanic did some research and told us that it was cause by misfire so we changed and plugs. Keeps happening, so we replace all the coils. Still happening, so replaced cylinder head temperature sensor and still happening.
Anyone have same issue and find a solution? Next step is changing the coolant crossover pipe, but that looks like a pretty big job and would like to see if anyone has found better solution.
  • Had a jeep that did the same thing. Changed water pump and put a new radiator in and it was cured.
  • water pump and thermostat. Our neighbor got that and he keep stopping and checking it and in the end replace the engine. The water pump had lost a blade. Not sure why they was over look on his or yours.
