cdl2's avatar
cdl2
F53 Ford Chassis?
I just bought a Dolphin on a F53 chassis.
I need info!!!!!
Shocks?
Sway bar bushings?
Steering damper?
Exhaust modifications?
Thanks!!!!
  • Shocks-------------Koni FSD
    As for the rest, if something is worn or loose, fix it, but if it has been maintained and has less than 100,000 miles, the bushings etc should be fine.
    The V10 had pretty good exhausts and the bang for the buck probably won't be very good for any performance mods.
    Some sound deadening material under the doghouse might be helpful (it was on mine anyway).
  • cdl2,
    First thing I recommend, join the Great Lakers, or the Noreasters. They are both FMCA Chapters with National RV (Dolphin) owners. Lots of info there!
    Secondly, after driving, what do you think of the handling? Also, check the dates on the tires. If they are 5 years old, or more, then I suggest you get new ones. Michelin & FMCA have a special program which will save money on Michelin Tires. Your life rides on tires and brakes, I want the best in those categories.
    Happy Trails! :W
    Darryl
  • It's a 2001.....sway bars front & rear.
    It has air bags front & rear also.
    35 foot long.....20,000 total .....GVWR?
    I blew one tire, so I checked & I need at least one more.
    Glad it wasn't the front tire!!!!
  • Banks trans command, Scan Gauge II, front track bar, steer safe, poly bushing if yours are bad.
  • Do you know the year, chassis weight capacity, length. Those items will help.
  • New? Used? What does it already have on it? A lot of variations i.e. brands of some add ons
    I added Steer Safe
    Roadmaster rear anti-sway bar
    Blue Ox rear trak bar
    Front & back Ford factory anti-sway moved to
    back holes. Back can be moved. Front I used longer Helwig hangers.
    Handles very well with those mods.
