dodge guy wrote:
RLS7201 wrote:
rgatijnet1 wrote:
Before I would spend any money on bolt-ons I would do the basics first. In other words load the coach exactly as it is when you travel with full fuel and fresh water(if you fill your tanks for travel), as well as food and clothing. Then have ALL four corner weighed and adjust your tire pressure according to the manufacturer's specs. The next would be to take it to an alignment shop, while the coach is still loaded for travel, that can deal with motor homes and get a front and rear axle alignment or a thrust angle alignment. Some shops will tell you that your rear axle is not adjustable when they DO NOT have the equipment available to set the trust angle on an RV chassis. It can be adjusted.
After you have done these things, and you still are not happy with the way the coach drives, then try some add-ons, one at a time.
Tell us how you adjust the rear thrust angle on a gas chassis with no provisions for adjustment? The spring hangers are bolted to holes in the frame, the spring draw bolt head aligns with a hole in the axle tube. There are no cams, no adjustable rods, etc.
Richard
Glad I'm not the only one. I do alignments daily. Rarely is the solid rear axle out of alignment. If it were it's very minor. Anything more and something is bent.
Thanks for jumping in dodge guy. I spent 11 of my younger years in the alignment business and still do alignment service on a call in basis and that patch shown by rgatijnet1 is just that, a patch. If the rear on our gas coaches needs adjustment then there are other problems also. Sure glad the non-professionals keep up professionals in line. :(
Richard
