bosco0104's avatar
bosco0104
Failed Smog Test
I have 1985 Class C Ford E350 with a 460 carberated engine. I just had the carb rebuilt and it is now running like a top. Carb is a Holley 4180 I believe. Problem is it failed its smog test today. I have turned a few wrenches and even rebuilt a motor or two but I am not good at diagnosing these types of problems. I have searched the web and forums for ideas and now I am turning to my fellow RVers. It did not pass the HC Test. The HC readings were 950 first idle and 1000 second test idle after reving the engine. Passing is 350. Where should I start? Should I lean out the air/ fuel idle mixture? If so how much? 1/2 turn ? 1/4 turn? I will check the timing but I am not sure about the dura spark distributior on it. Do I check it like a regular distributoir for time? Can it be the EGR valve? I just hate to throw parts at something without knowing whats wrong. Thanks for any help that you may have.
