FarmerBob's avatar
FarmerBob
false overheat
I have a 2006 V-10 on the F-53 , Had the temp gauge max out while idling. It went into limp mode, let it rest for a bit and it was fine. Engine did not seem hot at all, no antifreeze smell. When I got home put the scan on it and it said 253 deg.
Have read about this happening, but has anyone had this happen and did it come back or was it just a one time thing?
  • http://www.irv2.com/forums/f23/false-overheat-tsb-50007-2.html
    TSB
    06-21-15 MIL ON - DTC P1285 / P1299 - 5.4L 3V / 6.8L 3V - FALSE OVERHEAT
    Publication Date: October 13, 2006
    FORD: 2005-2007 F-53 Motorhome Chassis, F-Super Duty
    ISSUE:
    Some 2005-2007 F-Super Duty and F-53 Motorhome chassis vehicles equipped with a 5.4L or 6.8L 3-valve engine may exhibit an engine temperature gauge indicating an overheating condition with the malfunction indicator lamp (MIL) on with diagnostic trouble codes (DTCs) P1285 and P1299.
    ACTION:
    Performing normal engine cooling system diagnostics in Workshop Manual, Section 303-03, if it is determined that the engine is not physically overheating (coolant expulsion), install a new thermostat and crossover pipe. They have been revised for improved cooling system flow characteristics.
    PART NUMBER PART NAME
    7L3Z-8575-A Thermostat - 5.4L
    7C3Z-8575-A Thermostat - 6.8L
    3L3Z-8C368-A Crossover Pipe - 5.4L
    3L3Z-8C368-B Crossover Pipe - 6.8L
    WARRANTY STATUS:
    Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
    Note: Normal would be from 190 to about 220. The actual boiling point of the system is about 262. 212 water+5 for coolant +15x3 for cap pressure =262.
    __________________
  • I would take it to a good radiator shop, have the cooling system flushed, instal new belts, hoses and thermostat.
  • ?Thermostat hung up and then freed itself?
    If a scan showed that temperature I would sure replace the thermostat.
