murraymcleod wrote:
OK, I found the resistor assembly and removed it for inspection. It looked pretty much like the picture posted by AstroRig except the left coil resistor seemed to be tarnished...
Does the fact that the left coil looked corroded indicate it's necessarily bad?
That does not look like corrosion or tarnishing to me. That looks like thermal damage and I would almost bet that the adjacent thermistor blew and spewed hot gases on the coil giving it that appearance. Does it look like molten metal has leaked out the ends of the thermistor?
Per the Parts Catalog for your motorhome,
2003 SUNOVA ICD27C D-SERIESThe part number for the entire resistor assembly is 103930-01-710 and it is available here:
Winnebago Outdoor, Victory 035-0006 RV/Auto Fan Speed Resistor (Fused)The other alternative is to solder another thermistor inline, leaving the old one in place, as is done at the link below (on a Monaco) but life is too short for that for me.
http://www.irv2.com/forums/f115/dash-a-c-blower-speed-switch-117793.html
