chuckftboy
Apr 13, 2018Explorer
StuckinTracy wrote:Richard_999 wrote:
MY wall stat , has the label ... HONEYWELL Fan Tastic on it , so it is part of the system... BUT ... it operates WEIRD !
If you turn it down to BELOW the real temp... it comes ON !
That seems like the opposite of what it should do .
Richard
Sounds to me like it is doing what it should. If the temp is 70 and you set the dial to 65, it should turn on and cool until the temp reaches 65. Maybe I missed what you were saying.
Had one in an 98' Newmar and that is exactly how it should operate. If set below the room temperature, it will run until the room drops to that setting, then turn the fan off. Think cooling thermostat, like your a/c but without a compressor.
