By not working, if you mean the cover does not open then it is a common problem that sometimes the gasket will stick. Mine did a couple times. I climbed on top and lifted the cover to get started then it worked fine until I did not use it again for a period of time.
Called Fantastic Vent and they sent me some stuff (silicon or similar wipes) to clean the gasket with. No problem since, even after lengthy periods of non use.
Call them. They have very good customer service.
Fantastic Vent
201 E. Simonton St.
Elkhart, IN 46514
800-521-0298
