quietjake's avatar
quietjake
Field observations on our new Trail Lite 213
Now have accumulated 500 miles on 2 different camp outings.
Pros & cons:
Our 2004 Trail Lite 23' has low range mileage (33000) on the 6L Chevy platform. I really like the way it drives & handles. Dual rear tires offers considerable stability in road condition to date. It also was quite nimble scampering over the 4800'+ Willamette Pass both directions. Don't have a hard mileage yet until next gas fill, but seems to be between 11+ and 13+, running to the Oregon coast & up to Newberry Crater/East Lake....(the OTHER "Crater Lake" in Oregon).
I'm growing more pleased with the motor-vehicle aspects of the rig.
Will be adapting to the nuances in type of camping as different from the "park the TT and leave" vs the "tuck stuff in and take it along" approach.
Do NOT want a Toad, and have only about 2000# extra to stay below the GCVWR or whatever they call it these days. The rig with all supplies/fluids was right at 10,000# with the listed limit 12,000.
Cons:
Biggest negative is the bed lack of comfort. We've tried the queen size air mattress, which is a definite improvement, yet still not "good".
Did the 'you use the table/space' and I'll use the unfolded couch bottom...which was better but still not what I'm after. Maybe change to bunk bed frame instead of the folding couch???
The actual biggest issue is the noise of various cabinets, etc.
We've got the household goods/pots/pans pretty well dampened down, but the sudden noises from various bits of cabinetry etc is annoying.
On good roads, this is minimal. Usually. The noise volume grows and changes unpredictably. After over 400 miles, suddenly one of the drawers flings itself open multiple times...and not even on corners.
Nothing sounds like cables/etc behind the walls, as a couple RVers posted.
Tips/comments/hints/soothing sounds?
  • j-d's avatar
    j-d
    Explorer II
    I agree that you can avoid using a Toad with that compact RV.
    But, the GVWR (Gross Vehicle Weight Rating) is the max the COACH (with contents and passengers) is allowed to weigh. You don't carry your Toad IN the RV.
    The GCWR (Gross COMBINED Weight Rating) is the sum of what your RV weighs and the weight of what it's towing. Be sure you're working with the appropriate rating. The GM chassis doesn't offer as high a GCWR as Ford, but I doubt it's as low as 12000. 12000 sounds like GVWR.
  • When we bought our used trailer before we ever slept in it I bought the 4 inch pillow top for our short Queen. It wasn't cheap but we sleep better in our tt then our house. Very comfortable vs without.
