StuartT's avatar
StuartT
Filiter Minder Pegs in Red
On the trip home from North Carolina after purchasing my coach, I noticed the Filter Minder was fully in the red. So I stopped in Oklahoma and purchased a new air filter, Fleetwood #AH8503.
When I arrived in Arizona, I noticed that once again it had pegged in the red. I carefully examined the ducting from the intake up on rear cap to the filter minder sensor port just past the air filter. A little more research and I confirmed that this filter cross references with a Donaldson P537488 which is what is spec'd in my owner's manual. I have no idea, nor can I find info on the CFM ratings, but it does bring up an issue. This is the same filter spec'd for a 400hp ISL. An ISL is 543 cu. in., a 600hp ISX is 912 cu. in. which ingests a lot more combustion air. Either these filters are way overkill for an ISL, it may be they are inadequate for an ISX.
Replacing the Filter Minder would be a cheap troubleshoot up front and I am planning to do that. I am also looking for other possibilities to consider since we are currently set up for the winter/spring in an RV park and will not pull out until April. If this is not the right filter for an ISX, or someone else has run into this before and has more information, now would be a good time for me to find out about it.
  • Try the Cummins forum here on IRV. Better yet phone Cummins and they will tell you if that is adequate.
  • There is a Yahoo Monaco owners group. You should join it and post your question there
  • HI Fred, Banks might have a solution but before I see the big $, I am hoping someone has experienced this and has a cost effective solution.
    I am just as surprised Moisheh, I would have bet money an ISX filter would be larger. Yes, just bought this one in December in Myrtle Beach. Lots of things needing attention are popping up to keep me busy.
    I did post this on IRV2 as well and am waiting for a response post from a retired Fleetguard rep. Will share here if I learn anything.
  • Stuart: I am surprised you have the same filter as my ISL. Is this unit new to you? I would get onto the IRV2 forum and post your problem. There are some really knowledgeable Sig owners on that forum.
    Moisheh
  • You might want to get ahold of Banks Engineering. They have improved the air intakes and exhaust systems of many motorhomes, and really know what they are talking about.
    Perhaps you could somehow get dual air filters, and then have 'overcapacity' of your own!
    Fred.
