gonervn501
Dec 22, 2015Explorer
Filling Batteries
I'm looking at the Flow-Rite Pro-Fill battery watering system for my Allegro. From what I have seen they seem to work well. Does anyone have thoughts on these?
bluwtr49 wrote:
. . . . . . . The only small issue is the hand pump bulb has a check valve that occasional gives a problem.
Batteries stay clean, no mess, no corrosion, pretty much as advertised.
A lotta to do over nothing. Just another gimmick and expense. How hard is it, really to check the water level in a battery ? It takes so little time and allows you to check for other potential problems in the battery drawers (boxes) or whatever. Things like loose or broken wiring at the battery terminals, corrosion, etc.
DSDP Don wrote:A lotta to do over nothing. Just another gimmick and expense. How hard is it, really to check the water level in a battery ? It takes so little time and allows you to check for other potential problems in the battery drawers (boxes) or whatever. Things like loose or broken wiring at the battery terminals, corrosion, etc.
Wow....this couldn't be more wrong! I've been using the ProFill system for over 7 years on two different motor homes. Even if your batteries are easy to get to and you can stand right over them and fill them, it's still a messy/nasty job. You have to unscrew each cap, fill each cell checking that you don't under fill or over fill. You ultimately will spill some water which adds to your acid issues and you have to make sure you don't touch any clothing and wash your hands thoroughly when done. The ProFill system doesn't blindly fill the batteries from ten feet away. You're still able to look over your battery bay while conveniently filling the batteries.
One of the biggest causes of battery failure is that people hate to fill their batteries, so they aren't as faithful about doing it.
Not only does the ProFill system take under five minutes from start to finish to water up your batteries perfectly, it also reduces acid build up because of the cap design.
The ProFill system is one of the best products you can buy for an RV. They're expensive, but WELL worth the money.
Canadian Rainbirds wrote:I did on my last system. The caps and floats were flawless, but about 3 years in I started running into ball valve problems.bluwtr49 wrote:
Never had a problem with the check valve. The squeeze bulb only needs a few squeezes to get the water flowing IF you hold the water source above the batteries gravity does the rest of the work.
