Daveinet
Mar 22, 2014Explorer
1BryNelson wrote:
Let's look at fact your removing Sat dish. Never going to put back or mount something else up there???
Maybe silicon up the bolts and put them back in. Put a layer of silicon over. You should be maintaining roof once a year minimum, so you can reseal as necessary.
Then if you need a mounting place for something on roof...wahla!!
Bird Freak wrote:
I would put 1/4 inch stove bolts in the holes and cover with self leveling Dicor.
OK, now we have 2 people on the right track, although I would recommend stainless bolts or plastic bolts. Put a little sealer around the bolt and thread it back into the hole. Using a bolt will fill the hole with something solid that is held tightly in place, and will never get knocked off or work its way loose. It will allow you to scrub the area with out fear of tearing into the edges of the sealer. The idea is to have the bolt protect the seal an keep it secure. I've done this on my boat in a high traffic area, and it worked very well.
