wildmanbaker
Mar 25, 2014Explorer
People are trying to give you 2 options. The quick and dirty, "old Oky" fix, and the one you can be proud of. If you removed a sat dish, there is more than just 2, 1/4" holes. There should be a rather large round one for the operating mechanism to operate from the inside. Unless you go with the good fix, I would be inclined to cut an aluminum cover, and bolt it over the existing mounting hole, using butyl rubber caulk to seal the under side. This would look acceptable, and still allow someone to mount a new dish antenna at a later date.
