snowyegret52's avatar
snowyegret52
Finally got to take her out. Now come the questions.
So we got our 1986 Fleetwood Bounder parked up on our property in Vermont and FINALLY got to go for the weekend and test out everything.
Questions are:
1. The generator. Started up just fine but when I went to move the knob from choke to on, it dies. Kept the knob sort of in between choke and on and it stayed running. I know I need to change the spark plug and wire since it's been sitting for a few years but is there a fuel filter I need to change too? Onan generator
2. The Refrigerator. Runs great while the generator is on but when I put it on gas, I can't hear any ignition clicking to light it and it doesn't work. It's a Dometic 2852. Is there a way to manually light it or see if the ignition is clogged or something?
3. The furnace. How does it come on? I put the dial on the wall on 80 degrees to see if it would come on but nothing happened. Is there some other switch?
4. Battery. I know where the engine battery is but where is the deep cycle battery for the RV? It must be deader than a doornail because nothing works on DC no matter how long I ran the generator.
Other than that. Everything works great and considering its nearly 30 years old, that's saying something. The roof leaks like a sieve but we tarped it and it's fine now.
Any help is appreciated.
Thanks
Pamela
  • Once you find that 12V (or 2 6V in series) you may have solved part of the problem. The furnace, refrig, wsater pump, and possibly water heater all take 12V from the house battery. There is a good chance that old gas has accumulated in the generator. Try some Seafoam to try to clean out the jets. If that fails you could be looking at a new carburetor. Old gas lines also deteriorate to gennys so that could also be your problem. A crack in the line will let it suck air and lean out to where it won't run without the choke.
  • never heard my fridge light, furnace needs 12 volt .find or put a battery in that will solve a lot of problems.as for gen pull rubber hose off at carb and crank it,mine has filter just before carb but my problems have been rubber hoses
