Empty_Nest__Soo's avatar
May 24, 2013
Finding dual pane windows on a used motorhome
Looking to buy our first motorhome, and one of our "must have" features is dual pane windows.
Having attended a few RV shows and visited a few dealers in WV, Ohio, and Kentucky, my experience has been that dual pane seems to be available only on MHs where it is standard equipment. My impression is that dealers do not order dual pane as an option for new units for their inventory.
Since we will be buying used, and since I'm likely to have to travel a great distance to find a MH that meets our needs, I've done a lot of research to determine what makes and models and what years of MHs have dual pane glass as standard, expecting that my choices will be limited to those. I expect that I should forget about any realistic possibility of finding dual pane glass on a MH where it was an available option.
Is this a reasonable expectation? Or are there areas of the country (perhaps the North) where dealers will commonly order the dual pane glass option, so used units with it will be more common?
Thanks,
Wayne
  • One of the largest dealers in the country is right here in Florida. Dual pane windows perform as well in hot temperatures as they do in cold weather. The last time I looked at Class A's on their lot, most of the used units that were newer than 2000, had dual pane windows. I think that most of the mid range, and above Class A's will have dual pane windows and that some of the entry level class A's may not. If you are looking for older than 2000, you may find it a little more difficult to find one with dual pane windows.
