ctpres
Feb 05, 2016Explorer
Gallifrey wrote:
Any advice or guidance on how to figure out where to wire the power to under the dash? I'm comfortable with electronics and using a multi-meter to figure out what's on/off with the engine, but there are a ton of wires down there, most of which don't look like the type that should be tapped in to.Thanks.
If you have or will be adding other devices such as GPS, dash cam, camera monitor, etc. think about adding a 6 to 10 position fuse block wired to battery thru a dash switch. When done driving flip one switch and everything turns off.
