j-d
Aug 16, 2018Explorer II
Our HWH is manual and always moves two jacks at once. Supposed n to prevent that twisting. It does NOT. I sight down the side, see how racked it is, and try to adjust. Coach door still works though. At this point I'm usually frustrated since I want to run one jack but HWH runs two. And, ours are kickdown, so by then the jack I had to pull to vertical manually now needs it again.
Our system's one PITA. I truly hope you work yours out and it does well for you.
