theoldwizard1
Sep 21, 2017Explorer II
MetalGator wrote:
For the oil filter, do all Ford V10s take the same filter? I know there is different V10s in different trucks/RVs.
path1 wrote:
Question...do the newer Fords need the motorcraft oil filter with the built in silicon valve like older Fords?
The engine blocks for the Ford V10 is identical in all applications. The recommended oil filter is the Motorcraft FL820S, the S is for silicon. These are available at a reasonable price at most Walmarts. While there, pick up Motorcraft synthetic blend oil. It is what the factory uses can is also reasonably priced.
