MR_MAC
Sep 25, 2017Explorer
I took care of the hard (very hard) to get oil in the fill tube, by taking of the dog house cover inside the MH, and pulling off the oil fill hose. I made up a flex hose aprox 12" long and a cut off trans. funnel clamped together, slip it over the fil nipple on the valve cover and easy in goes the oil. At the same time I can check out all conn ections etc. on the mighty V10.
On draining the oil I Have an oil drain pan with two plugs in side, take out the plugs and the old oil goes in side the pan res. container. I rest the oil drain pan on top of the front axel.
