willald
Sep 25, 2017Explorer II
MR MAC wrote:
I took care of the hard (very hard) to get oil in the fill tube, by taking of the dog house cover inside the MH, and pulling off the oil fill hose. I made up a flex hose aprox 12" long and a cut off trans. funnel clamped together, slip it over the fil nipple on the valve cover and easy in goes the oil. At the same time I can check out all conn ections etc. on the mighty V10.
On draining the oil I Have an oil drain pan with two plugs in side, take out the plugs and the old oil goes in side the pan res. container. I rest the oil drain pan on top of the front axel.
I hadn't thought of going in from the doghouse to put the new oil in. That's a good idea, think I may try that next time. Thanks for the idea. ??
Was kind of funny to hear original poster talk about how he just did the first oil change. Pretty much everything discussed here in this thread, he talked about dealing with.
