smeador's avatar
smeador
First RV!!!
My lady and I just got our first RV. Used 25' 1990 Tioga Montara. Really exceptional shape, 85K miles, all systems working! We have been tent campers for over 40 years and decided it was time for an RV.
We are excited and nervous at the same time. We are planning several short local trips to get used to the rig in the next week or two. Then a run to Hatteras. And we are in the planning stages of a two or three week run out to Arizona and Utah before the snows hit.
Just wanted to say hello...
  • Bordercollie really hit that nail on the head with recommending checklists.
    Print that checklist, laminate it and keep it on the dash so you DO NOT FORGET to run the checklist every time you start up and move. Someone just posted how he ripped the awning off because he decided to take a quick jaunt without walking around first. Make it habit to ALWAYS do a final walk around with that checklist.
    Jose
  • Thanks everyone! We have been checking out most of the systems in the driveway and going over all the books and info. We are heading out next Tues. morning for a short trip to try out everything else. So far, so good...
  • Standard advice: 1.Safety: Make sure tires are no older than 5 years per date codes and have no serious sidewall cracking. Have brake fluid flushed and brake system serviced as needed, including replacement of front brake flex lines, if originals. Have engine cooling system tested including belts, hoses, water pump, radiator and clutch fan. 2.Comfort: Test operation of lights, fresh water pump, toilet, shower, awning, water heater, furnace, RV generator, roof and dash AC, converter charger and house batteries. Make sure you have good sewer hose and accessories for filling fresh water and clean hose for camp water. Sanitize fresh water tank and plumbing with bleach water. Shut off low drain valves completely after sanitizing. Know how to get power from generator into the RV and how to start and shut down roof AC properly. ( Wait ten minutes to restart after shut down.) Don't forget prescription meds, cameras and chargers, personal items. A check list is helpful. It gets easier!!
  • Welcome!!
    Remember, long trips are just a series of short trips. You will gave a great time.
  • Welcome to the forum. We share your excitement, and perhaps we will see you down the road.
  • Welcome to the forum. WE owned a 25' 1998 Tioga Montara. Really enjoyed it. I did have to replace the fuel pump in Whitehorse, Yukon.
