Ivylog
Feb 28, 2017Explorer III
CCC is cargo carrying capacity and tag axle coaches will have 6000+lbs if newer and if older like mine 9,000+. Older coaches are require to have a sticker with the CCC posted, often on the back of a cabinet or mine is in the closet. Beside the drivers seat there is a sticker with weight info on it which should give you a close idea and it will post the tire pressures required to carry the max weight. Starting around 2003 it's hard to have much CCC in a 40' coach without a tag axle, but 4-5 years ago the single axle weight for MHs was increased from 20K to 24K lbs making it easier to have enough CCC it it has the 24K rear axle.
FT is full time.
Yes a awning can be added later but finding the support necessary for a Girrard is more difficult and NO a Girrard is not mandatory, but they sure are nice. On a used rig I would not change the type of awning.
In order for your guests to shower, they are going to have to go through your bedroom to to get to it... not so with just a full bath that is mid coach. Not sure how we survived in a 2-3 bedroom home with just one bath.
Good luck
FT is full time.
Good luck
38,782 PostsLatest Activity: Sep 10, 2026
