Mr_Mark1
Feb 28, 2017Explorer
Mr. Jeremy,
Can you give us the particulars of that Dynasty? Mileage, etc.?
Ivylog and I can give you a lot of things to look for.
For one, make sure the dip switches are correct on the air units. Each air unit has a dip switch along with the thermostat. If your thermostat is located at the end of the kitchen cabinet, inside the cabinet, hidden behind a panel is the back of the thermostat that has dip a switch.
Ours were not set correctly from the factory which made the front and middle air come on at the same time. Not good if you are on 30 amp.
Good luck and safe travels,
MM.
MM.
38,782 PostsLatest Activity: Sep 10, 2026
