427435 wrote:
I suspect this will only create another DP vs gasser argument, but I had a chance to drive a DP today. I, a friend, and the friend's BIL took the BIL'S 2002 38' Monaco MH to the Knoxville Nationals sprint car race. We did an all-nighter coming home to Minnesota and I took a 2 hour shift driving. My take-aways were:
Quieter when accelerating or climbing a hill or on-ramp but no quieter when cruising.
I see those a positive going to the DP. But your saying a engine which his humming along side your knees just as quiet as the engine 30' behind you ?? Not buying that one. I know for a fact there 's more heat in the rear bedroom on ours from the engine running. So there's no heat given off up front from the gasser into the driver area?
Acceleration on a par with my gas MH. We were pulling a Jeep Liberty. The Monaco had a 330 hp Cummins.
What was the weight comparison? Was the HP and torque comparable? If so your observation was correct and should be on similar weighing coaches and power. If the DP weighed more ( which probably does) then the comparison isn't the "same".
The transmission shifted fine-----glad there were 6 speeds due to the limited rpm range of the diesel.
That trans is superior to your gasser most likely if a Allison. But it's sound like you don't understand the difference in a Gasser vs Diesel engine. That's how they operate build power and torque way down in the RPM range compared to screaming RPM's in a gasser. Max torque on our engine is at around 1800 - 2300 RPM's - compared to you probably around 5000 - 6000 RPM - thus your "engine noise". It also provides for longer lasting engines and better fuel economy ( in comparable weights ).
Didn't care for the front entry.
There are side entries
Ride over tar strips and bumps no better than mine (new shocks were recently installed).
What shocks? What tire pressure? Was it set to the tire manufacture weight specifications? Our ran rough, weighed it and set tire pressures. Night and day difference. Not sure your comment is valid here.
Swaying about the same as mine, also. Not impressed at all by the air ride that DP's are supposed to be known for.
[COLOR=]Air gags don't stop the sway shocks do. Koni shocks made a huge difference on our "new" MH only after a year. So springs are more comfortable than air bags. I think there're many here that have owned both would disagree. Your opinion is noted. However on bigger ( longer and heavier) coaches I think you'll you notice the difference. Maybe not so much on smaller platforms.
Steering precision maybe not quite as good (probably needs more caster).
Goes back to tire pressures and weight. Is load distributed evenly? Ride height adjusted correctly? Are you a steering specialist, how did you come up with more camber needed before verifying all the other variables?
Ended up in rain, and Monaco did a poor job of specing the wipers-----they did not cover as much of the window as my MH.
Is that a valid point for DP vs gasser? I don't think so.
Bottom line, I will not be rushing out to replace my older gasser with an older DP.
It' seems you have convinced yourself. Everyone has to be happy with what they have, and you seem to be. Nothing more to say. Have fun camping!!
Gasser or DP - no class warfare as far as I'm concerned. Too bad some feel that way. I certainly didn't when I owned TT or fivers.
