jlrmfc21
Mar 21, 2022Explorer
Janss wrote:
Reading your subject line, I thought your first trip was 18,500 miles long! Ha ha! Then I was surprised that from Midlothian VA to Park City UT was only 50 miles :)
1. I dread the day when I may purchase a newer motorhome with a Ford engine. Our Chevy 8.1 purrs like a kitten. But still slows down alot going up an incline. I don't worry about it. Just watch the RPMs and change gears as needed.
2. Sewer hose...You mean another one for additional length? Or a better one? Get the Rhino. It's a better one and they make extension lengths that just hook on to the main hose.
3. Wish I had tons of unused storage! Hoses and extra hoses (garden, fresh-water, sewer), chairs, small stepladder, wood blocks, tools, various bottles (antifreeze, oil, ant spray, WD-40, sometimes gallons of drinking water). Plus some things mentioned above. This is stuff in the outside storage compartments.
4. If the ground is too unlevel for the automatic leveling to work, first I put wood blocks under front or rear tires for support. Then use the auto leveling. If I can't make it work, I just won't park there.
6. If you use enough flush water, you don't need any treatments (as long as seals and vents are working properly). Sometimes I use Happy Camper or Unique Digest-It. Both are natural enzymes.
7. In theory I think that should work. But once I got a burnt surge protector when I turned on the generator while being plugged in. So I'll leave it to others to comment.
Excellent recommendations!
38,782 PostsLatest Activity: Sep 10, 2026
